A bug appears to be introduced after 4.12.0
Two fixtures in workspace, controlled by an X-Y pad. If you set a scene with only the X Pos and Y pos set so that you can control both lights simultaneously relative to the scene. This works fine in 4.12.0, but after that you find the second fixture is not controlled.
I've also found that adding more fixtures it becomes a bit random as to which fixtures are controlled by the pad. Version 12.0 appears to work brilliantly as expected for this amazing software!
X-Y Pad not controlling multiple fixtures
Please share a sample workspace to reproduce the issue. Thanks
- Real Name: Andy Bosley
Thanks for looking at this, I have not retried this as I have rolled back QLC for a show, but I did try it on both Linux and Windows builds.
- joystick test 2.qxw
- (5.31 KiB) Downloaded 69 times
