RGB-Matrix in the Brightnesschannel
MaxMeyer
Hello Massimo,
a lot of the RGB-Matrixeffects have only one Color. I use this monochrome Effects to generate sequences. In the sequences i switch off the RGB-Channels and use only the Brightness Channel of the fixtures. The advantage is, that i can choose a color of the sequence independent from the sequence. This works well when the Pixels are only full on or full of. But the in the RGB-Matrixeffects Brightness is done with the RGB-Channels, not with the brightnesschannel. So i cant use the effect independent from the color in the sequence.
I need an Option when i generate a sequence out of a RGB-Matrix:
"generate brightnessinformation of the effect in the brightnesschannel, not in the RGB-Channels"
Max
