Submaster Problem
MaxMeyer
in a FRame i have a fader configured as a Submaster. Inside this Frame is also a soloframe with two buttons. One is linked to a scene. This button works as expected. If the submaster is 0 the two lamps are off. If the Submaster is 255 the two lamp are 255, as programmed in the scene.
The second button is a sequence. If i press this button, the twi lamps beginn to blink at 255, but the submaster is at 0!!. When i now move the submaster a little bit, the values changes to the submastervalue. From now on the submaster works with the sequence like expected until the sequence is switched off and on again.
Regards, Max
Submaster.qxw
(5.35 KiB) Downloaded 61 times
softserve
Real Name: Andrew
Does it behave normally when the submaster is set to something between 0 and 255? If so, you can likely use a channel property to fix it. Basically you could limit the range of the submaster to 1-255, then use a channel property (in the fixture manager) to convert the dmx value of 1 to 0 on output.
MaxMeyer
thanks softserve for this workaround
