QLC Crashes when opening Fixture monitor
pgScorpio
Real Name: Peter Goderie
QLC 4.12.2 on windows 10
At some point in setting up a 'default' workspace QLC started crashing when opening "Monitor".
Attached the crashing workspace and it's latest backup which does not crash.
AFAIK I only added 27 scenes (in #Presets), with corresponding controls in virtual console, and changed some fixture channel modifiers (from invert to normal and vice versa),
and i changed some channel group names.
Also, as latest, I have been experimenting with external inputs (midi as well as dmx) and feedback , but those changes have all been removed again because I thought this was what caused the crashing.
Everything else like virtual console and simple desk seem to work normal though.
Fixture monitor crash.rar
(40.12 KiB) Downloaded 238 times
:geek: Software is the stuff that makes Hardware flexible ! :lol:
rajones203
Real Name: Russell
I just was having a similar issue with QLC+ v4.12.7
Seems I have been able to replicate it. I thought it was adding loopback channels (and thus overloading the fixture monitor, ie. in the 2d view with too much stuff to look at). However I had noticed you said something about inverting a channel's curve. I undid an invert and POOF its stable again. I'm not sure what the issue is, but if you all want I'll upload a crash report.
Since the focus is and should be on v5 at this point, I'm not asking for a fix, just want to bring awareness and give you the gotcha. I'm 99.9% sure this is causing the crash.
______
Russell Jones
Lighting Hobbyist
rajones203@gmail.com
Channel modifiers (if this is what you're talking about) are an engine feature, so they will be dragged into v5 seamlessly.
So if there is a crash in using them, I would appreciate if you can instruct me how to reproduce the crash and I can eventually fix it. Thanks
rajones203
Real Name: Russell
I’ve been working through it but it seems to be a problem with a fixture profile for me. I re saved the file under a different manufacturer and re-added it and that’s how I got around it. I’m sure that badly written fixture profiles can cause crashes. For example. I accidentally added two heads to a fixture while messing around and when I tried to fix the profile this issue started.
______
Russell Jones
Lighting Hobbyist
