Hi there! I just learnt about DMX and me being Linux nerd, QLC was pretty much obvious choice and it works pretty great, only things that I'm missing are ability to control things by oscillators and I didn't quite get synchronizing to music right (Lightkey for Mac does this pretty good IMO). Those are things I probably can't help with, but I am able to make a logo, which I also thought could use some love
Here's what I came up with:
Let me know if you like it, and if you'd like to use it, what files I should provide
New logo design
- Real Name: Marek Jędrzejewski
I updated it a little bit, cause I didn't like 4 bars on the bulb base:
EDIT: Can't decide now. 4 bars version resembles letter Q more, and that was one of my goals, 3 bar version has big difference between contour width and base width and loses that a bit. I tried to make 3 bars version out of 4 bar version before, but that didn't look good, so I shrunk the contour to make it work without 4th bar. For 3 days I'm like 'yeah, it's fine now' and when I return I make another changes, cause I don't think that anymore
Hi, thanks for this.
I like it but I think it needs some more adjustments.
For example, what about a transparent background version? What if the background is black?
QLC+ logo is everywhere and it must look OK in any condition.
Can I send you an email so that you can send me a vectorial version?
I posted preview only, so I tried to show possible versions (black on white, white on black, totally flat, with a bit of gradients), of course it can have transparent background, should also work with different colors than yellow, but might sometimes need a little adjustment, but that's what different versions and vector graphics are formcallegari wrote: ↑Mon Jan 13, 2020 10:16 am Hi, thanks for this.
Yeah, send me e-mail and I can send you files, and we can figure out what works best
I believe for small sizes it would need another, simplified variant, something like this 16x16 version. For bigger sizes changes wouldn't have to be so drastic
I tried making size variants, but the fact that plus is not really visible on small sizes became apparent. Even on 48x48 which is not that small it was barely visible. It's much better with colors from the opposite site of color wheel. I don't know how important yellow color is for the logo, but plus should be white or whiteish at least in color version. If yellow is not that important, maybe using other color would be better option?
Anyway, here's svg if anyone else would like to play around with it (extension changed to .txt as forum wouldn't let me upload svg):
Tadam! Has yellow for lightbulb and plus is visible even on smaller sizes
- Real Name: Tommy
Speaking as a graphic designer, I think the purple as a contrast colour feels a bit chocolate box, I agree with the need for the scaled icons, but the flat (no drop shadow) and black and yellow gives this a very clean, and contemporary look which takes the projects existing design and brings it forward into the 2020s rather than the 2000s. It does this by using the flat style and moving away from the skeumorphic style of the original.
Simply put, the original colour scheme on the new vectors would likely look better.
I liked the original colors better too, though it really does make plus invisible on smaller sizes, and this version is fixing that.0002 wrote: ↑Fri Jan 17, 2020 4:07 pm Speaking as a graphic designer, I think the purple as a contrast colour feels a bit chocolate box, I agree with the need for the scaled icons, but the flat (no drop shadow) and black and yellow gives this a very clean, and contemporary look which takes the projects existing design and brings it forward into the 2020s rather than the 2000s. It does this by using the flat style and moving away from the skeumorphic style of the original.
Here's the size adjusted version with original colors swapped. Didn't make it flat, cause shadows help shapes be more visible, and plus is barely visible on 16x16 and 24x24 version and only somewhat visible on 32x32. Only thing that makes it visible is using darker color on it, and that's the thing that emits light in a lightbulb, so I don't think that it should be darker except for black on white version.
Anyway, here's svg version so you can play around with it too (but have to change extension first):
I've added the SVG extension to the forum
Can you please attach the yellow version of the last screenshot?
I attached version with colors grouped together, so it can be easier checked how certain combinations look, unfortunately, I getmcallegari wrote: ↑Sat Jan 18, 2020 12:56 pm I've added the SVG extension to the forum
Which prevents me from uploading it, so it's txt again:Error
It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct.
I really love this look.
@Massimo would you be interested in myself and @marekjedrzejewski collaborating on a test version with new theming for QLC+?
I'm excited to help more on the Dev side and have some experience with graphic design. My plan would be to start with 4 then move to 5 once we're happy.
Keen to get your thoughts.
Cheers
Cheers
Hey Massimo,
I've modified the design based on your feedback. I'd really appreciate you taking a look and telling me what you think.
Here are the main adjustments:
Here is an SVG.
Here are the 64 and 128 px exports: If all is well I'd like to work on the other UI element icons.
Kind regards,
Lachie
- Transparent Background concern has been taken care of through it being a circle.
- Background can be any colour as there is enough padding to separate it.
- Contrast has been increased through outlining the "+" and increasing the relative thickness of the "screw" relative to the "halo"
- The impact of the "Q" is increased through moving the screw closer to the centre
- The impact of the lightbulb image is increased through the addition of a "Live" terminal at the base.
- QLC+ Users like to keep it simple. The drop shadows and small curvatures have been removed to aid this.
Here is an SVG.
Kind regards,
Lachie
I still have a concern regarding small icons.
For example, look at the Chrome tab above: you can still recognize a Q, while the + is barely visible (but getting closer is still a +)
This new icon becomes a black circle inside a yellow circle. Can't really recognize it compared to a larger version.
I played a bit with stroke weight in Inkscape and it improves a bit but I still need to think about it
Changing logo is not something trivial
How about something even more minimal, something similar to this?
I couldn't resist Massimo...
You Nailed the Bullet?
YES YOU DID
-my deeply profound respect to you buddy-
