Undo/redo touch usage
Ask a question related to the QLC+ 5.x usage here.
Provide as much details as you can, especially what you would like to achieve and if available, a sample workspace of your work in progress
memrex
Hello
It is possible to undo/redo editing steps with the shortcuts CTRL+Z and CTRL+SHIFT+Z. How can you use the undo/redo feature on a mobile device?
When using undo/redo, it would make sense to jump to the appropriate tab. Otherwise, you might e.g. accidentaly undo a fixture change while viewing the virtual console.
