RGBScript works in DEV Tool, but not in QLC+
mruttenn
Real Name: Menno
Dear all,
I rewrote one of the provided RGBScripts. My version does work in the QLC+ RGB DEV Tool but it does not work in QLC. I am running version 4.12.2
EDIT: Removed _spacing in getSpacing function
My RGB code:
  Q Light Controller Plus
  spacedstripes.js
  Copyright (c) Menno Rutten
  Licensed under the Apache License, Version 2.0 (the "License");
  you may not use this file except in compliance with the License.
  You may obtain a copy of the License at
      http://www.apache.org/licenses/LICENSE-2.0.txt
  Unless required by applicable law or agreed to in writing, software
  distributed under the License is distributed on an "AS IS" BASIS,
  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  See the License for the specific language governing permissions and
  limitations under the License.
// Development tool access
var testAlgo;
  function()
    var algo = new Object;
    algo.apiVersion = 2;
    algo.name = "Spaced Stripes";
    algo.author = "Menno Rutten";
    algo.spacing = 2;
    algo.properties = new Array();
    algo.properties.push("name:spacing|type:range|display:Spacing|values:0,7|write:setSpacing|read:getSpacing");
    algo.setSpacing = function(_spacing) {
      algo.spacing = _spacing;
    algo.getSpacing = function() {
      return algo.spacing;
    algo.rgbMap = function(width, height, rgb, step)
      var map = new Array(height);
      for (var y = 0; y < height; y++)
        map[y] = new Array();
        for (var x = 0; x < width; x++)
          if ((step % (algo.spacing + 1)) === (x % (algo.spacing + 1)))
              map[y][x] = rgb;
              continue;
          map[y][x] = 0;
      return map;
    algo.rgbMapStepCount = function(width, height)
      return width;
    testAlgo = algo;
    return algo;
The DEV tool shows multiple stripes but QLC+ shows only one.
Can someone help me with this? Thanks in advance.
maybe this
algo.getSpacing = function(_spacing)
Remove _spacing. A get function does not need parameters.
mruttenn
Real Name: Menno
mcallegari wrote: Wed Dec 11, 2019 7:55 am maybe this
I tried this but it did not solved the issue.
