VECTTOR DMX USB not working win version 4.12.2
- Real Name: Ajejandro Guerrero
Good morning, in the new version 4.12.2 my Vecctor interface stopped working correctly, works fine in the previous version 4.12.1. On the Outputs tab, its shows the following: "System Timer Accuracy: Patch this widget to a universe to find out". I really need OS2L, so thanks in advance for your attention and possible fix.
Lower the output frequency to 30Hz.
You can clearly see the difference from the screenshots you provided.
I was in contact with the interface developer. He tells me that for some strange reason in the new QLC version, a driver that is not correct is being selected and that creates conflict, but not with the previous version that does work correctly.
In the previous version it detects Manufacturer FTDi, in the new one it detects it as Enttec.
