xUbuntu 18.04 install trouble
jeffryz
Real Name: Jeffry
Hello everyone, I am using instructions at https://software.opensuse.org/download. ... lcplus-qt5
to install manually.
I run into trouble on the last command of the ubuntu 18.04 instructions.
sudo apt-get install qlcplus-qt5
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package qlcplus-qt5
Using synaptic package manager I do see qlcplus-qt5:amd64. I try installing it, but I get lots of dependency errors.
sudo apt-get install qlcplus-qt5:amd64
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qlcplus-qt5:amd64 : Depends: libasound2:amd64 (>= 1.0.16) but it is not installable
Depends: libc6:amd64 (>= 2.17) but it is not installable
....and so on.
Just needing some help...thank you!
