Not sure about this one.
As per attached, 5 fixtures in 3 RGB matrix configurations all with the default 500ms hold times.
The pars transition one to another every 500ms as you would expect.
Add them to a chaser with 4s fade in,fade out and 8s hold.
I think what is happening is that the 4s fade in is overwriting the 500ms because you get to a point where almost no lights lightup.
ie Its worse second time around the loop.
Change the chaser fadein to 0ms and it runs as you would expect.
Change fadein to 1sec and you can see that it is slowing down the "internal"RGB transition(hold) times.
As to why im fading between RGB matrices is a long winded story. I have simplified the file below and the explanation to its rudiments.
4.12.2-Chaser(fadein) of RGBmatrices- affects RGBholds
- Real Name: Mark Sy
- RGBChaser.qxw
- (4.92 KiB) Downloaded 55 times
