I was in the process of recreating a test workspace I use when experimenting with 4.12.2 and noticed that if I change the virtual console size the change isn't being saved. Other changes, say to the widgets and grand master are saving as expected.
As a work around, I could edit the file directly.
MacOS 10.14.6
Resize Virtual Console
maybe this post would be better in VC-Forum (viewforum.php?f=33)
Resizing the workspace is also not applied at clicking th OK-Button in Virtual Console properties.
QLC+ 4.12.2 amd64 on debian 10
Confirmed. Resize doesn't work anymore.
Working on it...
[EDIT] already fixed. Test versions on the way
Working on it...
- Real Name: Mikey Rowlands
Ooooo was just looking for an answer to this one, Thanks
- Real Name: Marco Manieri
Hello Massimo. Looks like the fix is not included in 4.12.2 ?mcallegari wrote: ↑Thu Oct 03, 2019 8:02 am Confirmed. Resize doesn't work anymore.
Working on it...
Marco Manieri
Perugia - Italy
Perugia - Italy
As written above, test versions:
viewtopic.php?f=12&t=3135
