error at update
de DJ Fabriek
Real Name: Tiago Vilhena de Oliveira
I got an error while installing
hf.deb
(Reading database ... 37824 files and directories currently installed.)
Preparing to unpack .../qlcplus_4.12.2_armhf.deb ...
Unpacking qlcplus (4.12.2) over (4.12.2) ...
dpkg: dependency problems prevent configuration of qlcplus:
qlcplus depends on libgles2; however:
Package libgles2 is not installed.
qlcplus depends on libpulse-mainloop-glib0 (>= 0.99.1); however:
Package libpulse-mainloop-glib0 is not installed.
qlcplus depends on libpulse0 (>= 0.99.1); however:
Package libpulse0 is not installed.
qlcplus depends on libqt5core5a (>= 5.8.0); however:
Package libqt5core5a is not installed.
qlcplus depends on libqt5gui5 (>= 5.11.0~rc1); however:
Package libqt5gui5 is not installed.
qlcplus depends on libqt5multimedia5 (>= 5.6.0~beta); however:
Package libqt5multimedia5 is not installed.
qlcplus depends on libqt5multimediawidgets5 (>= 5.6.0~beta); however:
Package libqt5multimediawidgets5 is not installed.
qlcplus depends on libqt5network5 (>= 5.8.0); however:
Package libqt5network5 is not installed.
qlcplus depends on libqt5script5 (>= 5.6.0~beta); however:
Package libqt5script5 is not installed.
qlcplus depends on libqt5serialport5 (>= 5.6.0); however:
Package libqt5serialport5 is not installed.
qlcplus depends on libqt5widgets5 (>= 5.11.0~rc1); however:
Package libqt5widgets5 is not installed.
dpkg: error processing package qlcplus (--install):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Processing triggers for systemd (232-25+deb9u4) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for shared-mime-info (1.8-1+deb9u1) ...
Errors were encountered while processing:
qlcplus
Last edited by de DJ Fabriek on Thu Aug 29, 2019 10:40 am, edited 1 time in total.
de DJ Fabriek
I placed the file on a usb stick and uninstalled QLC 4.12.1. Then installed with cmd sudo dpkg -i /media/usbstick/qlcplus_4.12.2_armhf.deb and received an error message.
on which image?
de DJ Fabriek
This one
[LINK DELETED]
I asked you which IMAGE (mine?, Raspbian lite?, Raspbian full?, Stretch?, Buster?), not which FILE you used. (which is clearly in the useless log above)
Moreover, do you understand not everyone has access to the deb file for Raspberry? If so, then why did you post the download link?
I think you should try to understand how Debian works first. If it says "package is not installed", then you should install the missing packages. Doesn't seem difficult to understand to me.
de DJ Fabriek
sorry I posted the link, I hadn't thought about it. I am not an expert with the raspberry. I figure out this.
