Still Can't see fixture even after file add to app
The issues found when using the Fixture Manager panel
trinityswitch
Real Name: Aly Howe
Hi I'm still having trouble seeing new fixtures.
I am a Mac user and new to the programme.
I have copied a new fixture into the correct place so it should show in the library: 'show packed contents/Resources/Fixtures etc. But when I try and see it in the library when adding a new fixture within the programme it is not there. I even tried just adding a new folder and naming it to see if the programme was recognising changes in these folders but again I can't see any changes when trying to add a new fixture in the QLC programme.
Is there a solution or any way around this? Way to physically import the profile in a new project?
That's not where you place new fixtures
See #4 here: https://www.qlcplus.org/docs/html_en_EN ... swers.html
daz
Real Name: Jeff Dasler
I have the same problem. And there was no folder for user fixtures in Library/Application\ Support/. So I created it and copied the file in there. Still nothing.
lighthacker2020
Real Name: Mr Mike
These are the paths on a Mac:
$HOME/Library/Application Support/QLC+
                                     /Fixtures
                                     /InputProfiles
                                     /MidiTemplates
                                     /ModifiersTemplates
                                     /RGBScripts
Sounds like you need to drop the fixture definition in $HOME/Library/Application Support/QLC+/Fixtures.
(and restart QLC+ afterwards, so they get included)
