Hi
Wonder if anyone can help?
I have suddenly started to experience very slow startup of QLC+ on a Mac.
The program seems to hang as the startup progress bar is almost complete or after it has disappeared. I have tried reinstalling but it doesn't seem to help. Once the program is running all seems fine.
I am using the latest version of QLC and the Mac is fully up to date.
Thanks in advance.
Slow Startup on Mac
- PiotrNowik
- Real Name: Piotr Nowik
It's not only Mac issue.
I experienced similar problem on my laptop with Windows 10. When I click on QLC+ icon it starts after 10-20 seconds.
I'm using still the 4.11.2
Generic USB-DMX box(es)
Korg nanoKONTROL2
Windows 10
Korg nanoKONTROL2
Windows 10
- Real Name: Maddix
I'm having the same issue, I think.
QLC v4.12.2 on Max OSX
When I open QLC+ I immediately get the mode selection dialogue box. If I choose fixture editor it opens right away.
If I choose Q Light Controller Plus, it takes 45 seconds (!) to load. Nothing is shown on the screen during that time.
It also takes 45 seconds to load a very basic workspace (one RGB fixture and one scene).
Worked fine when I first got it. What got corrupted?
I'd suggest to delete the QLC+ configuration file and try again.
See https://www.qlcplus.org/docs/html_en_EN ... uning.html to find the file.
Might be some plugin configuration slowing the startup.
- Real Name: Maddix
Great, thanks. That fixed the slow startup time.mcallegari wrote: ↑Tue Aug 25, 2020 12:16 pm I'd suggest to delete the QLC+ configuration file and try again.
It still takes almost a minute to load a project file with one fixture and one scene.
EDIT: I created a new project with one fixture and one scene. That one loads in a second. The previous project with one fixture and one scene loads now in 15 seconds. There should be no difference, at least logically. Another project with more fixtures takes about a minute.
I guess it's the same issue: in the project file you're loading a plugin which is slow to load (maybe MIDI? Non-existant network interface?)
You could try to edit/empty the InputOutputMap block at the beginning of the project file.
- Real Name: Maddix
That seems to be the case, thanks!mcallegari wrote: ↑Tue Aug 25, 2020 4:57 pm I guess it's the same issue: in the project file you're loading a plugin which is slow to load (maybe MIDI? Non-existant network interface?)
Massimo, any chance you can take a look at my recent thread about jitter on the Artnet interface when enabling more than one universe? That's unfortunately keeping me from moving forward with QLC+ and I haven't been able to get it sorted out. Grazie!
- Real Name: Lelieveld
Yes I have had this slow startup problem on PCs.
I prepared a 7 universe show, then copy the file to the production laptop and there it takes a few minutes to load the file.
Deleting the <InputOutputMap> segment in the file fixes this problem.
So it looks like the IP settings are giving this behaviour. Perhaps this can be looked at ?.
I any tesing is required I am offering my time ..
If a network interface is not found, QLC+ will retry a few times and see if it's just being raised by the OS.
This has been implemented for the Raspberry Pi, to catch a slow DHCP server or a lazy network interface.
Can be useful on PC too where QLC+ is started at boot time.
In other words: when porting a project to another PC you need to adjust the IO map and adapt it to the new IO config.
- Real Name: Ben Croft
An option on boot to program offline would be awesome or select setup. I sometimes carry my laptop without the controller rack to prep. It houses the dock which is my network card and usb interface. The slow down is a nightmare but if we had an option on boot, that would fix that particular issue for me.
psst: if you open your project file, you can simply delete to entries for your devices and save. Now your project will open without the timeouts...
Warning: create a backup before editing. If you break the structure of the project file, you break the project in total.
