I'm using windows 10 and the enttec Open DMX USB is only sending the first 127 channels. I've tried the default windows driver (possibly a arduino driver, not sure) and uninstalled that and installed drivers from https://www.ftdichip.com/FTDrivers.htm. I've tried on two different windows PCs. However I plug the device into my Mac and it works perfectly so it isn't a HW issue. What drivers should I use or is there another setting I should change on Windows?
Thanks in advance.
Enttec Open DMX USB only sending 127 channels on Windows
- Real Name: Ken Coughlin
I have 6 Enttec OpenDMX USB dongles, which I run on Windows XP, Windows 10 x64 and Mac. I use the driver downloaded from Enttec, and I've never had that problem.
http://www.ftdichip.com/Drivers/CDM/CDM21218_Setup.zip
- Real Name: Kyle Sims
I am having that issue currently also. I have completely uninstalled all the drivers and reinstalled them and still only sending channel 1-127. Any known fix to it?
I can successfully control a lamp on address 177 on Linux
[EDIT] tested on Windows too. No problems
