I got a testcase with this equipment
Raspberry pi3
Sdi7” touchscreen
Enttec pro
Powered by 3A power adapter
sometimes when a show is running the raspberry fails/crash and has to be Restarted. it's not at a specific show. I also sometimes have the problem on a MacBook. but I don't know if this is the same problem, but I have a log of this.
Crash Raspberry Pi
- Real Name: Tiago Vilhena de Oliveira
- Touch DDF 17-3-2019.qxw
- (397.46 KiB) Downloaded 37 times
- Pdf.pdf
- (102.9 KiB) Downloaded 42 times
I replaced the power supply in the hope that the problem would be solved. but unfortunately this did not help. yesterday I had the problem again.
can the problem be in the sd card? I am using a Class 3 SD card and will try a Class 10 soon.
Please try the latest test version on macOS first.
I've made some changes in the attempt to avoid crashes.
It needs to be tested for hours/days though, so I need some help with that.
If it turns out to be solid, then the next Raspberry Pi version will be solid too.
I will test this version
I got the first crash for now. Run the app on a mac for.
- Q light stopped 7-4.pdf
- (117.8 KiB) Downloaded 48 times
Hi, thanks for testing and for the trace.
Indeed there was a mistake in the code.
I've just uploaded a new test version for macOS.
Can you please try again?
Otherwise, can you instruct me how to reproduce with a sample project? Thanks.
I'm going to try this version. I used the above project and actively used it for a few hours, then there was nothing wrong. then I let him walk on a chase for a long time and I got the crash
I cant use the project above cause it uses custom fixtures and I can't seem to find the chase you're talking about in the VC.
