Good morning Massimo,
When creating a sequence you are able to enter a scene name. This scene name is automatically used as a track name when adding the sequence to a show. That's pretty cool and works great. But if you now copy this sequence and rename the scene name I would expect the show function to add a new track with the new scene name when adding this sequence, but it does not. Instead it appears in the 'original' track. The only thing that works for me is creating a new sequence from scratch with a different name. I hope I explained it in the proper way but for me it is easy to reproduce.
I work with Mac OS 10.4.3 and QLC+ 4.12.1
Best regards,
Gerard
[closed, no respons] Cloning a sequence to use in show function appears in 'original' audio track
If your problem is only the name of the sequence... change it inside the project file. (With a text editor ... make a backup first: if you break structure of the file you brake the project.)
If you expect a new track inside your show because you clone a sequence? Uhmm.. I wouldn't want that at all...
- Real Name: Gerard van Hamburg
If you clone a sequence you can leave the scene name as it is. Then it appears in the same track. But if you rename the scene name then I would expect the sequence to appear in that track. If you don't want it, leave the scene name as it is.
