QLC+ on Raspbian desktop
Posted: Wed Mar 13, 2019 8:43 pm
I have installed raspbian desktop on an old laptop to try it with QLC+ but I am unable to install the .deb file.
At first I tried using qlcplus_4.12.1_armhf.deb but when this failed I tried qlcplus_4.12.1_amd64.deb
I tried something similar with the X-Air software. The raspberry pi version failed but the Linux version installed and appears to work fine at the moment.
When installing QLC+ I get the following errors:
pi@raspberry:~/ $ sudo dpkg -i qlcplus_4.12.1_amd64.deb
(Reading database ... 127345 files and directories currently installed.)
Preparing to unpack qlcplus_4.12.1_amd64.deb ...
Unpacking qlcplus:amd64 (4.12.1) over (4.12.1) ...
dpkg: dependency problems prevent configuration of qlcplus:amd64:
qlcplus:amd64 depends on libasound2 (>= 1.0.16).
qlcplus:amd64 depends on libc6 (>= 2.17).
qlcplus:amd64 depends on libfftw3-double3 (>= 3.3.5).
qlcplus:amd64 depends on libftdi1.
qlcplus:amd64 depends on libgcc1 (>= 1:3.0).
qlcplus:amd64 depends on libqt5core5a (>= 5.9.0~beta).
qlcplus:amd64 depends on libqt5gui5 (>= 5.8.0).
qlcplus:amd64 depends on libqt5multimedia5 (>= 5.6.0~beta).
qlcplus:amd64 depends on libqt5multimediawidgets5 (>= 5.6.0~beta).
qlcplus:amd64 depends on libqt5network5 (>= 5.8.0).
qlcplus:amd64 depends on libqt5script5 (>= 5.6.0~beta).
qlcplus:amd64 depends on libqt5widgets5 (>= 5.2.0).
qlcplus:amd64 depends on libstdc++6 (>= 5.2).
qlcplus:amd64 depends on libudev1 (>= 183).
qlcplus:amd64 depends on libusb-0.1-4 (>= 2:0.1.12).
dpkg: error processing package qlcplus:amd64 (--install):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Processing triggers for gnome-menus (3.13.3-9) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for shared-mime-info (1.8-1+deb9u1) ...
Errors were encountered while processing:
qlcplus:amd64
qlcplus:amd64
