ArtNet node discovered in QLC but no output to pixels
- Real Name: Jay Adams
Hello, I have been trying to get an Arduino ArtNet node to work. I connected everything correctly it seems, as when I load the sketch, the LEDs run a quick test sequence. When I set up the IP settings in QLC, everything seemed fine. QLC said that the node was discovered though I am not getting any output to the pixels. I am currently using an Arduino UNO running IDE 1.8.7 with an ethernet shield connected to WS2811 LEDs. I am fairly new to this and any help would be appreciated. Thanks.
You are sure that the Arduino is sending signals to your LED's in the first place? Or is that your statement 'load the sketch, the LEDs run a quick test sequence'?
Then manually configure a network address in your Arduino. (Don't rely on DHCP in test environments - you simply have to be sure) 10.x.x.x range with mask 255.0.0.0 as per (old) Artnet convention.
On your QLC+ host you will also arrange an IP in the same range (10.x.x.x)
From your QLC+ host - ping to the Arduino - just making sure it can see the Arduino.
Then ... you can start configuring the QLC+ artnet settings conform to the above settings.
Don't forget that Artnet is 10-based so universe 1 is in fact 0; channel 1 is 0...
It should be. After uploading the sketch for the ArtNet node, the LEDs light up. Though I cannot output from QLC. I have tried numerous IP settings and subnet masks. Everything manual. Here is the code.
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <Adafruit_NeoPixel.h>
// Neopixel settings
const int numLeds = 50; // change for your setup
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 5;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {10,0,0,2};
byte mac[] = {0x08, 0xE9, 0xE5, 0x00, 0x69, 0xEC}; // make sure this is different than any other mac address in your network
void setup()
Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
void loop()
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
sendFrame = 1;
// set brightness of the whole strip
if (universe == 15)
leds.setBrightness(data[0]);
leds.show();
// Store which universe has got in
if ((universe - startUniverse) < maxUniverses)
universesReceived[universe - startUniverse] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived[i] == 0)
//Serial.println("Broke");
sendFrame = 0;
break;
// read universe and put into the right part of the display buffer
for (int i = 0; i < length / 3; i++)
int led = i + (universe - startUniverse) * (previousDataLength / 3);
if (led < numLeds)
leds.setPixelColor(led, data[i * 3], data[i * 3 + 1], data[i * 3 + 2]);
previousDataLength = length;
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < numLeds ; i++)
leds.setPixelColor(i, 127, 0, 0);
leds.show();
delay(500);
leds.setPixelColor(i, 0, 127, 0);
leds.show();
delay(500);
leds.setPixelColor(i, 0, 0, 127);
leds.show();
delay(500);
leds.setPixelColor(i, 0, 0, 0);
leds.show();
looking into the code there is an instruction looking for universe 15 channel 0 which sets the intensity of your panel...
This should have given you a clue.
Id suggest as a test that you change the code (make a backup first)
add before the if instruction:
leds.setBrightness(255);
sendFrame = 1;
if (universe == 15)
leds.show();
