In the virtual console, I designed a layout that would not be super bright when the house lights are down by specifying a darker neutral background instead of bright white. When I run in Kiosk Mode, the background is not displayed and so the bright white background defeats my goal of a subtle display.
Design Mode
Kiosk Mode
Running on Redhat.
Kiosk Mode does not display background colour
[moderator] moved to proper forum area (that is not QLC+ 5)
- Real Name: Christian Marcus Cepel
Thank you for the correction. I was, from within QLC+, quite unable to find a standard 'about' box with software versioning information. Lots of help topics, but I failed to find an 'about'.
Now that it's in the proper forum... Is this a bug?
I need the project file to take a look at this. Thanks
Is this the correct file?
- HGC-20190208-QLightWorkspace.qxw
- (25.84 KiB) Downloaded 45 times
Did I provide the correct file requested?
Just tested on Linux. There's no issue. Kiosk mode is consistent with design mode.
Which OS are you using?
Redhat 29
Guess you mean Fedora 29...
Which DE in use ? Gnome ?
KDE seems to work as expected.
