Chaser with RGB Matrix does not consider fade out [Solved]
yokosuna
Having a - say - FillUnfill RGB matrix as a one shot.
Add this into a chaser.
For the first "run", the "fade out" of the matrix will be "disrespected" wherease the "fad out" works as expected.
When the chaser is rentering its loop, the "fade in" will be performed too !?
Version is 4.12
Sample attached.
thx
Edit: after closing the software and reopening, it´s working as expected... !?
Fade Issue.qxw
(5.15 KiB) Downloaded 67 times
Change your topic title as [solved] now? Would you please?
yokosuna
It´s NOT solved in respect of setting the chaser NOT to run endless
Sorry - did only read your last sentence
kenact
Real Name: Ken Coughlin
"It´s NOT solved in respect of setting the chaser NOT to run endless"
Your chaser is set up to loop, and you have a duration set on the matrix step. When you set a duration on a step, instead of Infinite, the step automatically moves to the next step, when it completes. Because you have the chase set as a loop, the next step is always FillUnfil Matrix.
Either set the chase to Single Shot or set the step duration to Infinite.
