Long story short, I've had to make several changes to the project loaded on my RPi.
How do I export that project back to my pc for backup / further development?
If it's using SSH can someone tell me the path to the file.
(Any chance of an export option being added to the web interface?)
How do I export a project from RPi to PC?
Well, it depends on where you saved the file in the RPi.
If you set it to be loaded at boot, then it's
There are several ways to pull a file out of the RPi.
Easiest one I'd say is to copy the file to a USB pendrive.
Another easy one (but filthy one!) is to copy the file to the /boot folder, which is a FAT partition that can be open with a Windows machine via SD card reader.
/root/.qlcplus/autostart.qxw
