as I have no idea how to use the splitted channel 1 or the lpt-like channels 2 vs 3 to 5, I decided to request the fixture definition file for this lamp.
Manual (DE, GB, F, NL): http://www.produktinfo.conrad.com/daten ... _fr_nl.pdf
Manual (PL): http://www.produktinfo.conrad.com/daten ... 3_IN_1.pdf
Manual (IT): http://www.produktinfo.conrad.com/daten ... 3_IN_1.pdf
Thanks in advance.
chasersync
Renkforce EL603
- Real Name: René Nikel
Hi"
What can you do on this lamp. This lamp function only on 8 channels. According to the manual. Refine you work with the lamp.
ch 3 R
ch4 G
ch5 B
and next
ch 1 is DIM if bit is 201-255 , dark 1-5ch is bit 1-127 maby.
ch 3 R
ch4 G
ch5 B
and next
So, I´m beginner on the QLC+. I´m working on ShowTec Controller 1024 Pro. I want to connect these devices...
I did it.
Could you please test it?
- renkforce-EL603-LED-Spot.qxf
- (3.39 KiB) Downloaded 93 times
