Hello together!
I'm trying to configure an Artnet over VPN.
Now my Problem is: how can I change the settings in QlC, so that the new network interface (exept of Ethernet and WLAN) is used for the Artnet Data?
Has anyone made a Project like this?
VPN Artnet
VPN is 'only' a tunnel between two endpoints build onto an ethernet connection.
If you want something to go thru that tunnel, you have to instruct to do so.
With your Artnet you will have to enter the receiver's IP-address. It will then decide to use the tunnel because it's the only way to get there...
(use unicast)
(use unicast)
