using Rpi3B+ to create wifi (no internet) for OSC, while still use ethernet for Artnet communication
djcflo
Real Name: coleman
Hello! This is my first post, and I've been messing with the Raspberry Pi and QLC+ for a couple weeks now...
I've been experimenting with using TouchOSC to control QLC over wifi, without the need to connect to a router or any internet - that is, I want the Rpi to be mobile and act as a hot spot wherever I bring it.
I also wanted to be able to communicate with Artnet via ethernet output. I struggled to figure out how to configure the Rpi as a hotspot without messing with ethernet communication. Every time I got the Wifi access point configured and running, it disabled my ethernet connectivity in QLC, or changed the settings enough that I couldn't connect with my DMXking LeDMX4 Pro LED strip driver.
here is a short tutorial I've written to get Wifi access point setup on a clean install of QLC. I'm using qlcplus_raspbian_stretch_20181110
first flash clean QLC image to SD card
step one - updating the software
connect via Ethernet to local network with internet
boot up, shutdown QLC
sudo apt-get update
sudo apt-get upgrade
say Yes
sudo reboot
step two, fixing wpa_supplicant wifi country code error
under QLC input/output, check the pi’s wired ethernet IP address
from computer, ssh into the pi
login with user/pass using pi/raspberry
type in
sudo nano /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
hit enter
in what is probably a blank document, paste:
ctrl_interface=/run/wpa_supplicant
update_config=1
country=US
control X to quit, Y to save, enter to get back to command line
sudo shutdown -h now
unplug ethernet
boot up the pi:
quit QLC
sudo raspi-config
change default password to something new
quit out with Finish
type in
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
hit enter
in document, directly under ctrl_interface add
country=US
populate the fields with your home network info
ssid=”home wifi name”
psk=”home wifi password”
sudo reboot
under QLC input/output, check the pi’s new wifi-based IP address
ssh in over wifi
decide what you want your QLC box’s wifi to be called, and an 8-character password for it. replace that in WIFIPASS and WIFINAME in this script:
curl -sSL https://gist.github.com/Lewiscowles1986/fecd4de0b45b2029c390/raw/0c8b3af3530a35db9ab958defe9629cb5ea99972/rPi3-ap-setup.sh | sudo bash $0 WIFIPASS WIFINAME
sudo wget -q https://gist.githubusercontent.com/Lewiscowles1986/390d4d423a08c4663c0ada0adfe04cdb/raw/5b41bc95d1d483b48e119db64e0603eefaec57ff/dhcpcd.sh -O /usr/lib/dhcpcd5/dhcpcd
sudo chmod +x /usr/lib/dhcpcd5/dhcpcd
run
sudo nano /etc/network/interfaces
find
iface eth0 inet manual
and add a # before iface to disable the line
right below, paste in
auto eth0
    allow-hotplug eth0
    iface eth0 inet dhcp
sudo reboot
the pi should take a long time to boot up, it get's caught for about a minute "A start job is running for raise network interfaces"
I couldn't figure out what settings to tweak to fix this little hang up, but at the end of the process it works! my Ethernet acts with DHCP and communicates fine over Artnet (under input/output)
and my wifi works to connect with TouchOSC and successfully receives OSC signal.
I can connect with my laptop to QLC+ web interface if i still want to upload fixtures and load configurations or projects, and save the auto-start project as well.
I don't know how I would go about disabling it to run apt-get upgrade again, but for now, the box acts as a standalone hot spot that can still send signals out via ethernet.
I hope this helps someone!!!!
