[SOLVED] No sound when playing show
Posted: Sun Nov 25, 2018 11:25 pm
by didou64
I'm using latest version of QLC+ under Linux. See all details in my signature...
Got an issue playing Shows with audio file. There is no sound at all.
I tried different files with different audio format: mp3, ogg, wav, flac. Same issue...
I checked Audio tab in Input/Output section. Default device is checked for input and output.
Audio file is in the same directory than the workspace file.
There is not space in filename
I open same workspace in QLC 5 on same computer. And it worked like a charm without any modification.
Please, could you help me on that one? I'm a little bit lost...
Thanks in advance.
PS: issue is the same when I try to play sound file added in Function tab
Re: No sound when playing show
Posted: Mon Nov 26, 2018 12:12 am
by didou64
Issue is solved.
I uninstall QLC+, install QT5, reinstall QLC+.
FYI, I forgot to mentioon in my previous post. Current Ubuntu version is 18.04 updated from 16.04. Not a fresh install...
Don't know if it may cause issue.
Anyway, all is working now. :D
No sound at all
Posted: Tue Apr 23, 2019 6:51 pm
by teiko
I have the same issue with the same setup (Ubuntu 18.04 Mate, QLC 4.12.1) but my system is very freshly installed (4 days old) and I already have QT5.
Has anybody an idea what is going on there?
Regards,
Tim
Re: [SOLVED] No sound when playing show
Posted: Tue Apr 23, 2019 9:26 pm
by AllanR
Teiko, Have a look at http://www.qlcplus.org/forum/viewtopic.php?f=32&t=13344
I found that installing the mentioned package restored sound on my Linux Mint 19 (Ubuntu 18.04) PC.
sudo apt-get update
sudo apt-get install libqt5multimedia5-plugins
Hope this helps.
Posted: Wed Apr 24, 2019 6:47 pm
by teiko
Great, that solved it.
Thanks.
