Hi there,
i had a little Problem, when i created my Shows with QLC. I used different shows and in each show i used 1 audiofile (converted as wav). First of all i used 2 folders:
/project/audio/ -> Contains Audio files
/project/qxw/ -> Contains QLC Save files (workbench)
1: Its not a bug, but irritating: When i load a audio file from /project/audio/ - next time i want to save the workbench (save as), qlc suggests the /project/audio/ Directory for saving, even when i save all the time to /project/qxw/ - but when i want to load a file QLC suggests /project/qxw/ directory...
2: I load a audio file from /project/audio/entrance/song.wav to a show, then i save a new save (save as) to /project/qxw/ and load it, QLC forgets the path to the audio file and search it in /project/qxw/entrance/song.wav
I dont found any way to reproduce, but this bug was very frustrating, because i had to check all audio files before i go live...
Is here somebody who have the same problems? Can somebody reproduce it or can help avoid this problem?
QLC forgets audio path
Can you have a look in the project-file with a text editor ... maybe this gives a clue what's going on ...
And Massimo will need version and O.S.
And it might be already fixed on 4.12.0 test versions
[EDIT] just tested with 4.12.0 on Linux. Works as expected.
