Hi all,
I have an issue with the FX Editor:
When I want to apply an FX on a fixture, which has multiple heads but not generic dimmer channels or RGB channels e. g. UV intensity channels on each head, the FX will only be applied on the master dimmer channel.
However the FX Editor is recognizing the heads correctly, as you can see in the screen shot.
I am using QLC+ 4.11.2 on Windows 10 and added a SSCE along with a simple fixture definition.
It is also reproducible with QLC+ 5.0.0 Alpha 3
Is it a bug or am I missing something?
Thanks, Johannes
FX Editor fixture with multiple heads issue
- Real Name: Johannes Felber
- Test-UV.qxf
- (1.49 KiB) Downloaded 61 times
- uv-fx-ssce.qxw
- SSCE
- (2.56 KiB) Downloaded 51 times
