Dear Community,
Does anyone have an ideal how I can change the physical dimensions of the built-in RGB Panel (5x1 LEDs) so I can make it bigger in the DMX Visualiser? I've had a poke about the application package contents and there is a folder for fixtures (the one's QLC+ ships with) but the required item is not there.
Thanks in advance.
Hypernurd
Adjusting physical properties of Generic RGB panel
- Real Name: Aidan Bowen
Sorry all, should have been more specific.hypernurd wrote: ↑Tue Oct 09, 2018 10:41 pm Dear Community,
Thanks in advance.
Hypernurd
When you create an RGB matrix, you specify the physical properties. However, once created you can't (as far as I can tell) change them.
Anyone have any ideas? I've created a large amount of fixture groupings with my panels - I'd rather not have to recreate them !!!
Hypernurd
Those values are included inside your projectfile ... so make a backup first and then open it with the text editor of your choice...
You'll see it's a xml formated file. Be carefull not to break it (therefore the backup)
The width and height property of your panel are inside the fixture definition.
