Hello.
I am experimenting with lighting control with a cool 3D preview implemented on QLC 5 + Alpha 3.
So, as for the question, are not the preview of the strobe yet implemented in Alpha 3.0's 2D and 3D preview?
Even if you move the fader corresponding to the flash, the strobe will not work on the screen.
Does your strobe move?
Sorry for bad English. Because I am Japanese, I used translation.
Strobe does not work
I'm not sure, but it seems to be implemented.
Can you attach your workspace (.qxw) here with all custom definitions (.qxf)?
Did you update fixture definitions (.qxf) to the new format?
Does QLC+4 show strobe with your fixture?
To janosvitok
Thank you for your reply.
I will send the workspace and the file of the fixture I used.
Fixture has not been updated at all. All remains the same as when QLC 5 + was installed.
Actually, since I started using QLC + the other day (I used Freestyler before) I did not notice, but not only QLC 5 + but also QLC + 4 fixtures with many strobe functions do not work on simulation did. For now, I do not know about fixtures that can simulate strobes.
Is it a mistake in operation?
- American-DJ-64B-LED-PRO.qxf
- (4.2 KiB) Downloaded 152 times
- TEST.qxw
- (3.52 KiB) Downloaded 205 times
- Real Name: byronUnups
Text input is a system feature, the software does not have any control over that.
Maybe something went wrong with the Windows update?
Did you run a system check?
