Hi, I would like to know if this interface works with QLC +.
Follow the link:
http://www.lumikit.com.br/interface-dmx-lumikit-pro-1
Characteristics:
Can be used with wireless routers;
Allows multiple interfaces to be connected in the network;
Metal box with plugs for connection of power cables, DMX signal and ethernet network;
Automatic bivolt (115 / 220V) power supply;
Isolation of 1500Vrms between the network input and the logic circuit;
Isolation of 2500Vrms between the logic circuit and the DMX output circuit;
1 standard DMX RS485 output;
14 to 18 FPS (frames per second) with 512 DMX channels in the DMX output;
Art-Net version 14;
Compatible with Art-Net packages of type: ArtDMX, ArtPool, ArtPollReply, ArtIpProg, ArtIpProgReply,
ArtAddress;
interface lumikit
- Real Name: Presto Kowask
I can finally confirm QLC+ works with Lumikit. I tested it only using their Pro 2 product (https://www.lumikit.com.br/interface-dmx-lumikit-pro-2), but I guess it would work just as well with any of the more complex models, since they are newer.
