Hey,
I did a lot of programming on a working raspberry QLC+ installation.
Web access also worked for me.
I changed the "boot-project" and hit reboot. After that, the raspberry sticks at
Raspberry GNU/Linux 9 raspberrypi tty1
raspberrypi login:
when booting. How can I get back to auto-start QLC+?
Best regards
Noel
QLC+ boot problem
Just remove the autostart project.
If I remember correctly, it's in the .qlcplus directory.
would be interesting to know why it hangs though
I renamed the .qlcplus folder into qlcplus.
Now, QLC+ starts by itself after booting. But when I try to open the show, QLC+ crashes with the message "segmentation fault". Is there any way to repair the show?
Best regards
Noel
Best regards
Noel
Telepathically, no.
If you share the project, maybe yes.
Ok, I fixed it.
I opened the .qxw with nano and threw out block by block. After I removed a certain sequence, the project worked again .
Later, I found out, what might be the problem: the file is broken/empty if you edit the "autostart"-project, hit save an reboot. Since then, I'm working in a different project, safe it, copy it into the folder and rename it to "autostart.qxw". No more problems so far.
- Real Name: KimiSickinger
i'm not sure, if this problem is realy similar, but I have also a problem to load a default set Project after rebooting.
when I applay my Project as default on qlc+ and reboot the raspberry pi, it failes to start the Web Interace and the Desktop.
But the output of says is running and no issues.
When I delete the autostart.qxw file in /root/.qlcplus/, it start as normal with a planc project.
I have this issue just for files with self created fictures.
Here are my Files: https://drive.google.com/drive/folders/ ... sp=sharing
I use a raspberry Pi 4.
Thanks for help.
But the output of
sudo systemctl status qlcplus
Thanks for help.
I'd suggest connecting a monitor to your Raspi, hooking on a network cable, and starting from there debugging...
You have way too many parameters to deal with
- Real Name: Mark Z
I too have had issues editing the autostart file on the pi. If changes are needed to the autostart file, I usually make changes this way:
Quit QLC+ and return to the command line.
Rename the autostart.qxw file in /root/.qlcplus to something else as a backup
I transfer my new .qxw file to /root/.qlcplus and rename it to autostart.qxw
I reboot the Pi to let QLC+ utilize this the new autostart.qxw file on the next boot
This allows you to keep the autostart configuration on the Pi
