Crash after deleting Device with active function
Tasaei
Real Name: Jasper
Hi everyone!
So I 've got a little problem under OSX 10.13.4 and qlc 4.11.12 and didn't see anyone post it before.
To reproduce:
-New Project
-create generic dimmer (but the issue is with every fixture as far as I tested)
-create a new function and add the dimmer, don't "close" the function but just switch back to the device-section
-delete the dimmer
-go back to function manager (the function is still opened)
-remove the device from the function
-crash
in case didn't describe it well I captured it :
http://internal.jasperzevering.de/crashqlc.mov
bye
Tasaei
I can confirm this on Xubuntu 14.04 64Bit Qt5 with (some kind of) latest sources.
Fixed on GIT, thanks for reporting
