QLC+ 4.11.2 release
Here's the second patch version for the QLC+ 4.11 series.
This is mainly a bugfix and maintenance release, however a new feature is available on Virtual Console Sliders.
When dealing with external controllers that don't have motorized faders, you might want to 'catch up' with the current Slider value without undesired jumps.
Please check the updated documentation to understand how it works.
At this point, all my efforts are going on making QLC+ 5 production ready, so don't expect to see many more QLC+ 4 releases.
@Raspberry Pi users: I have a new image based on Raspbian Stretch that works with all the RPi models, including 3 B+.
At the moment I'm finishing to investigate some things, so an email with the new download links will be sent shortly.
I'll write a separate post for this 'porting' because it's been really painful this time.
Changelog:
  • engine: fix crash caused by an invalid IO mapping
  • engine: fix intensity override not considered during fade outs
  • UI/Function Manager: fixed keyboard shortcut conflicts and document them
  • UI/Function Manager: allow to import multiple of audio/video files at once
  • UI/Channel Groups: added expand/collapse all button helpers
  • UI/Chaser Editor: add a button to shuffle the selected Chaser steps (thanks to Felix Edelmann)
  • UI/RGBMatrix Editor: fix preview not updating on pattern change when play button is on
  • Show Manager: fix crash when adding a Sequence after deleting one
  • Show Manager: fix crash when editing a Sequence bound to a deleted Scene
  • Show Manager: fix items start time indication when dragging
  • Virtual Console/Slider: fix submaster initial value not applied and inverted mode
  • Virtual Console/Slider: added 'value catching' option for external controller faders (Lukas Jähn proposal)
  • Virtual Console/Slider: fix values range when switching between Slider and Knob appearance
  • Virtual Console/Slider: react on Scene flashing when in playback mode
  • Virtual Console/Knob: fix DMX values not updated when interacting with the mouse wheel
  • Virtual Console/Cue List: allow to select a step with next/previous buttons during pause
  • Virtual Console/Cue List: go to the right chaser step after a pause (thanks to Krzysztof Walo)
  • Virtual Console/Frame: fix regression preventing to send the disable feedback
  • Web Access: added support for VC Buttons in Flash mode (Sylvain Laugié)
  • Web Access: added support for VC Frame circular page scrolling (Sylvain Laugié)
  • Web Access: update AudioTriggers state when changed from QLC+ (Sylvain Laugié)
  • plugins/udmx: added 'channels' configuration parameter (see documentation)
  • plugins/E1.31: fix crash on wrong packet length (David Garyga)
  • New fixture: DTS XR7 Spot (thanks to Nicolò Zanon)
  • New fixture: Ledj Slimline 12Q5 Batten (thanks to Dean Clough)
  • New fixture: Ayra Compar Kit 1 (thanks to eigenaardiger)
  • New fixtures: GLP Impression X4 S, Eurolite LED KLS-2500 (thanks to Mitsch)
  • New fixture: Chauvet Intimidator Spot 255 IRC (thanks to Ham Sadler)
  • New fixtures: Chauvet Geyser RGB, Geyser P6 (thanks to Andrew)
  • New fixture: Chauvet Rotosphere Q3 (thanks to Eric Sherlock)
  • New fixture: Showtec Compact Par 7 Q4 (thanks to Alexander)
  • New fixture: Contest Delirium (thanks to Vincent)
  • New fixture: Solena Mini Par 12, Max Bar 28 RGB (thanks to Nathan Durnan)
  • New fixtures: Showtec Phantom 65, Laserworld PRO-800RGB (thanks to Piotr Nowik)
  • New fixture: Chauvet MiN Spot RGBW (thanks to Jungle Jim)
  • New fixtures: Showtec Shark Wash One, American DJ Vizi Hex Wash7 (thanks to Georg Müller)
  • New fixture: Showtec Shark Beam FX One (thanks to Mats Lourenco)
  • New fixture: Stairville novaWash Quad LED (thanks to Luke Bonett)
  • New fixtures: Eurolite Party TCL Spot RGB, Expolite TourSpot 60, Expolite TourStick 72 RGBWA (thanks to Dirk J)
  • New fixture: Chauvet Hemisphere 5.1, Trident, Scorpion Storm RGX (thanks to Francois Blanchette)
  • New fixture: Briteq COB Slim 100-RGB (thanks to Thierry)
  • New fixture: American DJ UB 12H (thanks to Jason R Johnston)
  • New fixture: American DJ Mega Hex Par (thanks to Ben C)
  • New fixture: Cameo Q SPOT 15 RGBW (thanks to Antoine Houbron)
  • New fixture: lightmaXX Platinum Line Flat Par COB (thanks to Leonardo)
  • New fixture: Stairville LED Blinder 2 COB 2x65W (thanks to chritoep)
  • New fixture: lightmaXX LED PAR 64 (thanks to Johannes Felber)
  • New fixture: Cameo Thunder Wash Series (thanks to JP)
  • New fixtures: Briteq BT 575S, Stairville MH-x30 LED Beam (thanks to Andres Robles)
  • New fixture: beamZ LED FlatPAR-154 (thanks to Jászberényi Szabolcs)
  • New fixtures: Eurolite THA-100F COB, Cameo Tribar 200 IR (thanks to David Morgenschweis)
  • New fixture: beamZ BT310 LED FlatPAR 12x8W 4-1 DMX IR (thanks to Mark)
  • New fixture: Fun Generation PicoWash 40 Pixel Quad LED (thanks to Harm Aldick)
  • New fixtures: American DJ Entourage, Elumen8 MS-700PE, Ibiza PAR LED 712IR (thanks to Tim Cullingworth)
  • New fixtures: Martin MAC 401 Dual RGB Zoom, MAC 401 Dual CT Zoom, Stairville MH-z720 (thanks to Tim Cullingworth)
  • New fixture: Fun Generation SePar Quad UV (thanks to Helmet)
