AppImage Linux test please ?
Hi, can someone please test this Q_Light_Controller_Plus-x86_64.AppImage bundle on his Linux distro and tell me if it works ?
Please report the Linux distro you used.
Fxedel
Real Name: Felix Edelmann
I' tried it on Ubuntu 17.10. by executing the referenced file. Unfortunately, it crashed during startup. See attached log:
$ ./Q_Light_Controller_Plus-x86_64.AppImage
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Abstract Twister 4"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "American DJ Galaxian 3D"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "American DJ XS 400"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Clay Paky Sharpy"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Coemar ProSpot 250 LX"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Equinox Gigabar"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Eurolite LED FE-1500"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Eurolite LED TMH-9"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Martin Atomic 3000"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Martin MAC Aura"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Martin MAC Viper Performance"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Showtec Kanjo Spot 60"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Showtec LED Light Bar RGB V3"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Stairville MH-X25"
"/usr/share/qlcplus/fixtures/Abstract-Twister-4.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/American-DJ-Galaxian-3D.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/American-DJ-XS-400.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Clay-Paky-Sharpy.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Coemar-ProSpot-250-LX.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Equinox-Gigabar.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Eurolite-LED-FE-1500.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Eurolite-LED-TMH-9.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/lightmaXX-CLS-1.qxf" not in FixturesMap.xml
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "lightmaXX Platinum CLS-1"
"/usr/share/qlcplus/fixtures/Martin-Atomic-3000.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Martin-MAC-Aura.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Martin-MAC-Viper-Performance.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Showtec-Kanjo-Spot-60.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Showtec-LED-Light-Bar-RGB-V3.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Stairville-MH-X25.qxf" not in FixturesMap.xml
qrc:/MainView.qml:21:1: module "QtQuick.Layouts" is not installed
qrc:/MainView.qml:20:1: module "QtQuick" is not installed
qrc:/MainView.qml:22:1: module "QtQuick.Controls" is not installed
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlags<QSurfaceFormat::FormatOption>(), depthBufferSize 24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize 8, samples -1, swapBehavior QSurfaceFormat::SwapBehavior(DoubleBuffer), swapInterval 1, profile  QSurfaceFormat::OpenGLContextProfile(NoProfile))
Abgebrochen (Speicherabzug geschrieben)
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+.
Very similar to my test on Xubuntu 14.04 64Bit
Pixel density: 4.90909 size: QSizeF(640, 360)
bool QLCFixtureDefCache::load(const QDir&) "/home/siegmund/.qlcplus/fixtures"
bool QLCFixtureDefCache::loadMap(const QDir&) "/usr/share/qlcplus/fixtures"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Cameo LED RGBW PAR64 18x8W"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Eurolite LED Bar RGB 252/10 40° Indoor"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Futurelight PRO Slim PAR-12 HCL"
bool QLCFixtureDefCache::addFixtureDef(QLCFixtureDef*) Cache already contains "Futurelight PRO Slim PAR-12 MK2 HCL"
943 fixtures found in map
"/usr/share/qlcplus/fixtures/Cameo-LED-RGBW-PAR64-18x8W.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Eurolite-LED-Bar-RGB-252_10_40__Indoor.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Futurelight-PRO-Slim-PAR-12-HCL.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/Futurelight-PRO-Slim-PAR-12-MK2-HCL.qxf" not in FixturesMap.xml
"/usr/share/qlcplus/fixtures/lightmaXX-CLS-2.qxf" not in FixturesMap.xml
bool QLCModifiersCache::load(const QDir&, bool) "/usr/share/qlcplus/modifierstemplates"
bool QLCModifiersCache::load(const QDir&, bool) "/home/siegmund/.qlcplus/modifierstemplates"
Loading RGB scripts in  "/usr/share/qlcplus/rgbscripts" ...
     "balls.js"  loaded
     "ballscolors.js"  loaded
     "circles.js"  loaded
     "evenodd.js"  loaded
     "fill.js"  loaded
     "fillfromcenter.js"  loaded
     "fillunfill.js"  loaded
     "fillunfillfromcenter.js"  loaded
     "fillunfillsquaresfromcenter.js"  loaded
     "gradient.js"  loaded
     "noise.js"  loaded
     "onebyone.js"  loaded
     "opposite.js"  loaded
     "plasma.js"  loaded
     "plasmacolors.js"  loaded
     "randomcolumn.js"  loaded
     "randomfillcolumn.js"  loaded
     "randomfillrow.js"  loaded
     "randomfillsingle.js"  loaded
     "randompixelperrow.js"  loaded
     "randompixelperrowmulticolor.js"  loaded
     "randomrow.js"  loaded
     "randomsingle.js"  loaded
     "squares.js"  loaded
     "squaresfromcenter.js"  loaded
     "starfield.js"  loaded
     "stripes.js"  loaded
     "stripesfromcenter.js"  loaded
     "strobe.js"  loaded
     "verticalfall.js"  loaded
     "waves.js"  loaded
Loading RGB scripts in  "/home/siegmund/.qlcplus/rgbscripts" ...
void IOPluginCache::load(const QDir&) "/usr/lib/qt4/plugins/qlcplus"
void AudioPluginCache::load(const QDir&) "/usr/lib/qt4/plugins/qlcplus/audio"
[Universe] setInputPatch - ID: 0 , plugin: "None" , input: 0 , profile: "None"
[Universe] setInputPatch - ID: 1 , plugin: "None" , input: 0 , profile: "None"
[Universe] setInputPatch - ID: 2 , plugin: "None" , input: 0 , profile: "None"
[Universe] setInputPatch - ID: 3 , plugin: "None" , input: 0 , profile: "None"
[Universe] setOutputPatch - ID: 0 , plugin: "None" , output: 0
bool Universe::setFeedbackPatch(QLCIOPlugin*, quint32) plugin: QObject(0x0) output: 0
[Universe] setOutputPatch - ID: 1 , plugin: "None" , output: 0
[Universe] setOutputPatch - ID: 2 , plugin: "None" , output: 0
[Universe] setOutputPatch - ID: 3 , plugin: "None" , output: 0
[InputOutputMap] setting beat type: 1
DMX source with priority 0 registered at pos 0
(qrc:/FixtureDMXItem.qml:20:1: module "QtQuick" is not installed)
(qrc:/Fixture2DItem.qml:20:1: module "QtQuick" is not installed)
(qrc:/Fixture3DItem.qml:20:1: module "QtQuick" is not installed, qrc:/Fixture3DItem.qml:23:1: module "Qt3D.Render" is not installed, qrc:/Fixture3DItem.qml:24:1: module "Qt3D.Extras" is not installed, qrc:/Fixture3DItem.qml:22:1: module "Qt3D.Core" is not installed, qrc:/Fixture3DItem.qml:20:1: module "QtQuick" is not installed, qrc:/Fixture3DItem.qml:23:1: module "Qt3D.Render" is not installed, qrc:/Fixture3DItem.qml:24:1: module "Qt3D.Extras" is not installed, qrc:/Fixture3DItem.qml:22:1: module "Qt3D.Core" is not installed, qrc:/Fixture3DItem.qml:20:1: module "QtQuick" is not installed, qrc:/Fixture3DItem.qml:23:1: module "Qt3D.Render" is not installed, qrc:/Fixture3DItem.qml:24:1: module "Qt3D.Extras" is not installed, qrc:/Fixture3DItem.qml:22:1: module "Qt3D.Core" is not installed, qrc:/Fixture3DItem.qml:20:1: module "QtQuick" is not installed, qrc:/Fixture3DItem.qml:23:1: module "Qt3D.Render" is not installed, qrc:/Fixture3DItem.qml:24:1: module "Qt3D.Extras" is not installed, qrc:/Fixture3DItem.qml:22:1: module "Qt3D.Core" is not installed)
(qrc:/SelectionEntity.qml:21:1: module "Qt3D.Render" is not installed, qrc:/SelectionEntity.qml:20:1: module "Qt3D.Core" is not installed, qrc:/SelectionEntity.qml:21:1: module "Qt3D.Render" is not installed, qrc:/SelectionEntity.qml:20:1: module "Qt3D.Core" is not installed)
void VirtualConsole::addWidgetToMap(VCWidget*) id= 0
void VirtualConsole::addWidgetToMap(VCWidget*) id= 1
void VirtualConsole::addWidgetToMap(VCWidget*) id= 2
void VirtualConsole::addWidgetToMap(VCWidget*) id= 3
(qrc:/ShowItem.qml:20:1: module "QtQuick" is not installed, qrc:/ShowItem.qml:22:1: module "QtQuick.Controls.Private" is not installed, qrc:/ShowItem.qml:21:1: module "QtQuick.Controls" is not installed, qrc:/ShowItem.qml:20:1: module "QtQuick" is not installed, qrc:/ShowItem.qml:22:1: module "QtQuick.Controls.Private" is not installed, qrc:/ShowItem.qml:21:1: module "QtQuick.Controls" is not installed, qrc:/ShowItem.qml:20:1: module "QtQuick" is not installed, qrc:/ShowItem.qml:22:1: module "QtQuick.Controls.Private" is not installed, qrc:/ShowItem.qml:21:1: module "QtQuick.Controls" is not installed)
Alright, thanks.
New bundle uploaded, same link. Should work now.
This required much more effort than I expected...
Works, I really love what I see ;)
sbenejam
On Xubuntu 17.10 64bit it works.
Good work Massimo.
floEdelmann
Real Name: Flo Edelmann
Seems to work well on 64-bit Ubuntu 16.04, too :)
Nice to get my hands on it for the first time instead of watching your videos only!
