Scenes disappears
CoS2000
Hallo @all,
there are another Bug in 4.11.1:
- Add 2 Scenes
- Add a Show and add 2 Tracks, that Using this Scenes
- Add another Show and try to add a Track - You cant select the 2 Scenes, they are not shown! In Function Overview, they are still there!
- When you delete the first Show (where you use the 2 scenes), save qlc and load it new, the 2 scenes are disappeard! In the Function Overview both Scenes are deleted!
Cant give a example, because this are 2 bugs. First you cant use a scene in different Shows. One Time used, the scene ist not shown anymore, when you add a track. Second bug is when you delete a show that conains scenes, the scenes will be deleted too!
Hope you understand what i mean...
Thanks for your Work on QLC! Its the best Software for DMX Management i found, but its buggy...Hope my 2 Cents will help to find and remove bugs!
Greetings from Germany
sbenejam
I think this is not a bug. Read this post http://www.qlcplus.org/forum/viewtopic. ... 687#p47687
CoS2000
But it makes no sense, because when i delete the track where a scene is used oder i delete the whole show, the scenes stays on hidden an cant reused on another position...
