Crash when hiting '^' key
NEA
Hi everybody,
Maybe I'm wrong but a friend of me has the same problem.
1) Open qlc
2) load a project (on my windows 8.1 whatever the project I load is the same behavior)
3) Play the project
4) hit the '^' key (on a french keyboard is the key between the 'p' key and the '$' key)
5) Qlc crash
OS: windows 8.1 English with local in french (keyboard, clock,....)
QLC version: 4.11.1
No midi controller connected
Windows is up to date (patches...)
Does anyone has this problem ?
EDIT:
It seems to be related to slider/fader
From an empty project create a fader/slider in the virtual console.
Start the project and hit the '^' key (two or tree times) => qlc crash
Î can confirm
W10 - French keyboard layout - latest build
create new project,
put 1 generic dimmer
in VC set a slider in level mode to that dimmer
run
try sliding slider -> expected behaviour
use the ^ 2 or 3 times -> QLC crashes.
(note: the ^-symbol is used ONTO other characters so the use of ^ would mean 2 keystrokes before OS 'sees' this character. Like in ô or â you have to press ^+ o)
(note2: tried it with other [special modifiers (like ¨ ´ `) <- NO problem ... so only with ^)
I am not able to reproduce this on Xubuntu 14.04 64Bit Qt5, German keyboard layout.
Me neither. Linux + italian keyboard
sbenejam
I cannot reproduce on Xubuntu 17.10 with spanish keyboard. I tried ^, `, ', " keys.
