Venue TriStrip3Z
JPfowl
I have a Venue TriStrip3Z with the following manual. It's simple enough to use a cluster of RGB heads but I'd prefer a full fixture definition if anyone has time.
Venue_by_Proline_TriStrip3Z_Manual.pdf
(1.07 MiB) Downloaded 64 times
floEdelmann
Real Name: Flo Edelmann
I've created the fixture definition in the Open Fixture Library. You can download the .qfx file from there.
JPfowl
Thanks again. Interesting note- if you set the fixture upright (so the text on the back is normal looking) then the zones are actually backward from how you have it diagrammed (3,2,1 not 1,2,3).
floEdelmann
Thanks for your real life test ;)
I've also updated the matrix order here. The resulting .qfx file hasn't changed neither.
