Fade in/Out overide
- Real Name: Ben Edwards
Would be great if you could have fields in the Virtual console that allowed you to override the fade in/out. The use case for this is using the Dump DMX values to set up the scenes and then having to go to them all and set fade in/out. I use lightfactory and I tend to setup all the scenes and set a fade in/put to 2 seconds.
OK, so this is what I envisage.
Define 16 buttons (button 01-16) mapped to functions (01-16). The idea is that the user can use 'Dump DMX values to function' to save up to 16 presets. If they type 01 it would save the DMX dump to button 01...
Speed dial widget (http://www.qlcplus.org/docs/vcspeeddial.html) seems to be exactly what I want. So if I set the Speed Dial to the function 01-16) I can use this dial to set the fade in/fade/out of there functions? I tried this but it still does a snap if I press the button, I'm really looking for a cross-fade. How do I tell the speed dial to override the fade in/out of the functions? Ideally, I would like one speed Dail that overwrites the fadein and fade out but having two, one for fade in and one for fade out is OK.
Thanks, here are the files.
- Generic-RGB-PAR-8ch.qxf
- (1.63 KiB) Downloaded 46 times
- cube.qxw
- (113.79 KiB) Downloaded 37 times
