Here is the fixture definitions for the Chauvet Min Spot RGBW. I followed all the guidelines, but this is my first moving head, I hope everything is OK.
The link for the manual is here: https://www.manualslib.com/manual/56088 ... -Rgbw.html
I also made .png files for the gobos not already in qlc. In the guidelines you suggest to ask the manufacturer but I do not know how, so please ask me for the files or explain to me how to share the files legally.
Have fun!
- Chauvet-Min-Spot-RGBW.qxf
- (7.49 KiB) Downloaded 120 times
As a rule we try to reuse representation of gobo's as much as possible. There are already a ton of images present.
(and franckly speaking if the image is a tad off of the result, who does care?)
Ok then, I updated the file in the original post with gobos included in the QLC+ installation. About half the gobos are exact, the other half is approximative (I wrote "approx" in the description when this was the case).
I just tested QLC+ with moving heads for the first time. Wow, this software is easy to use and powerful! I even plugged in an old joystick and it controlled my moving heads instantly. Wow!
Added, thanks
