Hello, I'm running QLC+ 4.11.1 on a Windows 10 PC. This is a relatively minor issue, but I was playing around with the virtual console's default settings and found that changing the default button width can adversely affect how a button matrix is rendered.
Typically for my virtual consoles, I prefer the buttons to be wider that the default 50 px square. I usually end up with buttons that are between 125 - 150px wide and 50px tall. Up until now I've always changed the buttons manually. However, today I decided to try changing the default settings and found that making the buttons wider doesn't change the default width of the panel rendered with a button matrix and can also cause the buttons to shift towards the left, until their completely outside the bounds of the panel, making them invisible.
Attached is a screenshot and a workspace illustrating the issue.
Changing the default button width adversely affects default button matrix UI
- Real Name: Brian
- DefaultButtonSize_MatrixUI.qxw
- (17.66 KiB) Downloaded 40 times
