Hi there, just downloaded the .deb for QLC+ 4.11.1 and was eager to try out the "detach a panel" feature.
Opened a new workspace, double-clicked on the bottom tab for "Simple Desk"... and nothing happened. I was expecting a new window to open with the Simple Desk detached.
Tried it again with an old workspace... still nothing.
Am I missing something, or does this feature just not work on Linux?
4.11.1: detach panel doesn't work?
- sbenejam
On Ubuntu 17.04 this feature works. What QLC+ version you are using, the Qt4 or Qt5 version?. I'm using now QLC+ 4.11.2 Qt5 from GIT.
- sbenejam
I tested it yesterday with an Ubuntu 16.04 and it really does not work. I suspect it may be a problem with the Qt5 version of Ubuntu 16.04.
On Ubuntu 16.04 Qt5 version is 5.5.1 on Ubuntu 17.04 is 5.7.1. I have not tried compiling QLC+ on Ubuntu 16.04 with a more newer version of Qt5.
- Real Name: Ben Cordes
Ubuntu 17.10, QLC+ 4.11.1 (downloaded the .deb, didn't build from source), and it seems to be linked against QT4.
libQtGui.so.4 => /usr/lib/x86_64-linux-gnu/libQtGui.so.4 (0x00007fc2054fd000)
libQtCore.so.4 => /usr/lib/x86_64-linux-gnu/libQtCore.so.4 (0x00007fc20500b000)
libQtScript.so.4 => /usr/lib/x86_64-linux-gnu/libQtScript.so.4 (0x00007fc2038ac000)
libQtNetwork.so.4 => /usr/lib/x86_64-linux-gnu/libQtNetwork.so.4 (0x00007fc202fe2000)
