Hi to all!
Sorry for my english...
I have a big trubble because my workspace (.qxw) is damaged ( but why?).
When i try to open workspace program open error window and telling - program QLCPLUS.exe is closing, windows try to find problems.
It happens only with one of my workspaces( most important for me because in this .qxw all my shows and functions). If i open another .qxw program works correctly.
Please help me. How i can open my workspace again?
Program closing when open workspace/
Can you attach your broken qxw here?
- Real Name: Aramais
shure
- Пробный.qxw
- (218.81 KiB) Downloaded 59 times
Confirmed.
I can fix the crash, but I suspect the issue is somewhere else.
I think you have a Sequence referring to a Scene that doesn't exist anymore.
This should be no longer possible since bound Scenes are now hidden.
Can you please explain what you have done to reach this situation ?
Hi Massimo. Very glad to talk with you.
It happens when i tried to create and insert RGB Natrix in my show.
After that i save .qxw, and thats all- program crashes and did not open anymore.
In general- program regularly crashes and closing, but such a serius arror wasfirst time.
Do you have a working backup copy of your project to share so that I can check the differences with the corrupted one ?
thanks
thanks
The more I look into this, the more I get really confused.
1- you have a Sequence named "Головы правые вверх вниз" which references a Scene named "Головы правые вверх вниз" which is empty !
Moreover, the Sequence references a Fixture that has been deleted. Can you confirm that ? Maybe it was worth to mention it since most likely it is the cause of all evil...
2- you have some EFX overlapping a Sequence on track "Головы правые вверх вниз". How is that even possible ? The Show Manager shouldn't allow you to do that
3- I noticed you copy many times EFX/RGB matrices in the Show timeline. Why ? By nature, EFX and RGB matrices loop indefinitely, so you just need to place them one single time and let it loop for the desired time.
[EDIT] attached your workspace fixed
- Пробный-fixed.qxw
- (217.34 KiB) Downloaded 60 times
Massimo. Great thanks for restored .qwx .
Uhfortunately i cant explain how the crush had happened.
1. I cant confirm about "the Sequence references a Fixture that has been deleted". I dont remember for sure.
2. Sorry, but if it happens (EFX overlapping) , so it possible. Any case the program gave me allowed. I could do it.
3. Not wery well with the program, thats why i may choose unrational way.
Hi Massimo. Uhfortunately critical error with the file after rebilding fixtures.
When i open your fixed Пробный-fixed.qxw ( great thanks!!!), i saw my fixtures the list but actually not work . After that i removed all fixtures and add again in the list. Then i save my QXW and when i try to open QWX the program open error window and telling - program QLCPLUS.exe is closing, windows try to find problems. Why critical error happens again? What i do incorrectly?
- Пробный-fixed.qxw
- (189.94 KiB) Downloaded 53 times
