Hey,
I like using QLC+ a lot. But I do have a question:
I can't use the 2D-View in the monitor with my 4 Spot TBar, because there's only one Spot displayed.
This also affects the useability of the RGB Matrix. Then only the outer Spots are flashing.
How do I get all 4 Spots of the fixture working?
I am using an Eurolite KLS 200. I'm encountering the same problem on my Involight COB Bar 815.
Thanks for the help in advance!
Cheers,
Kevin
Only outer Spot is visible in 2D-View
Most likely the fixture definition doesn't include heads, or you're using a mode without heads.
What is the manufacturer of 4 Spot TBar ?
As I already mentioned above:
- Eurolite LED KLS-200 RGB
- Involight COBBAR815 COB LED Matrix-Bar
Cheers,
Kevin
Cheers,
Kevin
Please try fixture definition for the Eurolite in annex.
I can't find the default Involight definition - so I assume a custom one?
- Eurolite-KLS200-V2.qxf
- (4.97 KiB) Downloaded 31 times
