Blind Mode/Freeze DMX output
schonemann
Real Name: Jan Schønemann
I would like to be able to edit a different Function/Scene than the one that is active - is on the stage.
Say during a rehearsal where I need to make corrections in a Function without disturbing the actors on stage.
So a button - next to the Blackout button - that would Freeze /Toggle DMX output.
In a way like - if I momentarily disconnected the DMX cable.
Thanks for a GREAT program ! !
Jan Schønemann
I have implemented it in QLC+ 5. You just need to wait
schonemann
Thank you!
So good !
Jan :)
psyka
Real Name: Jérôme
Can't wait :)
Thank you for your work!
andrewh
Real Name: Andrew Hallmark
Maybe I'm missing something, but isn't this possible anyway?
There's a blind edit mode, which is a button with an eye symbol on it, that allows you to change a scene without affecting what is currently being output.
This is a bit different from freeze, but I think it still achieves your objective.
