Good morning.
I am trying to use the "RGB matrix" function with 6 channel lighting fixtures, but I can not work and I want to ask why.
I refer to the reference image while looking at the link below.
https://youtu.be/ovr3CSSbfgY
I'm not sure if it's related to what I can not do,
When I tell you the difference from the video,
In the image(picture1), pressing the "fixture group" folder places one lighting fixture in a single compartment,
When I click on the "fixture group" folder, one channel is placed one by one (picture 2)
Is this related? If so, which part should I fix?
Or should I check out the other part?
I try to use "RGB matrix" but it does not work.
- Real Name: Lukas
Hey,
please first of all share your workspace file!
As a first guess I also would say you have the wrong type of fixtures in the group - should be a RGB fixture and not multi channel dimmers.
Regards,
Regards,
- Real Name: kim kh
hello
This is my workspace file!
thank you
- zzaptoong1121.qxw
- (22.07 KiB) Downloaded 41 times
- Real Name: Lukas
Just as I guessed, you used generic dimmers with multiple channels, so for every channel, there is created a separate head. Use proper fixtures (e.g. the generic RGB one) which will have only one head per fixture.
