QLC+ crashes on opening project
dirkV
Real Name: Dirk Verslype
I'm relatively new to QLC+ and was looking into the use of the loopback plugin to be able to fadeout audio on demand. I used the info I found on the forum to create a little test project where I start and fadeout a few audio cues in combination with a light scene. It worked as expected. When I opened the project a few days later, it made QLC+ crash. Now I'm not able to open it anymore.
In Ubuntu 16.04 I open QLC+ and when I try to open the project QLC+ just shuts down. I tried the same in windows 10 but there it doesn't work either. I get a message that QLC+ has stopped working.
I created the project in version 4.11.0. I installed 4.11.1 today in UBUNTU but it doesn't make any difference.
The project is in attachment. I'm I doing something wrong or is this really an issue ?
If this is not the right place to post my problem please let me know.
DirkV
loopbackchase.qxw
(6.74 KiB) Downloaded 69 times
Crash confirmed.
I don't how, but you have a dimmer on Universe 4 and that universe doesn't exist !
Most likely you removed it at some point, without removing the fixture first.
loopbackchase.qxw
(6.51 KiB) Downloaded 71 times
dirkV
Thanks a lot, Massimo.
By the way, I have fixed the issue upstream, so with the fixed version it is possible to open your project
aramais
Real Name: Aramais
Hi to all/ Same eroor- program crash when open project.
Пробный.qxw
(218.81 KiB) Downloaded 180 times
aramais wrote: Fri Dec 08, 2017 5:56 pm Hi to all/ Same eroor- program crash when open project. Пробный.qxw
Please don't hijack forum threads. Your issue is reported here: viewtopic.php?f=27&p=50159#p50159
and is a different issue from the one discussed in this thread.
