In one group i have two identical RGB devices with 59 RGB heads each. One is connected to Universe 1 the other to Universe 3 via two artNet channels.
If i use this group in a RGB matrix, only one device is showing the RGB effects (the one connected to Universe 1). The second device is ignored.
With Scenes or in the simple Desk both Devices are operating as expected.
I also tried other combinations (i have three Universe 1,3,4 running) but looks like only one Universe is used in the RGB matrix....
QLC+ 4.11.1 RGB Matrix only working with one Universe?
- Real Name: Alex Marques
The same thing happens to me
Not reproduced with universe 1 and 2. See attached.
I will try uni 1+3 later.
Is there any particular reason you're not using universe 2 ?
- rgbMatrix2Universes.qxw
- (11.12 KiB) Downloaded 101 times
Alright, tested 1+3 as well and no issue found.
Since I don't have the physical devices, I just checked the ArtNet packets with wireshark and they look correct to me.
- rgbMatrix2Universes(1+3).qxw
- (11.12 KiB) Downloaded 100 times
