No DMX out with a custom fixture
willmodelisme
Issue in Win10, 4.11.0 and and latest TEST version
Hello everyone.
I have just installed 4.11.0 and get issue with on of my custom fixture, the Varytec PAD7 Seventy RBGWA.
I have no DMX out with RGBMatrix.
It could be an issue with my fixture because it works well with other fixture.
My fixture passed the validation process and I was running previously the 4.10.4 with no issue.
I have checked with the latest TEST version and the problem remain.
Can anyone take a little time to try to check and help me to fix this issue ?
I joint a workspace with a scene and a simple RGBMatrix with 4 of my fixtures.
testROH.qxw
(3.26 KiB) Downloaded 89 times
Varytech-RGBWA-seventy.qxf
(2.22 KiB) Downloaded 94 times
Enttec DMX USB Pro
Windows 10
Found a problem in your fixture definition:
All intensity channels were set to 'fine' LSB
that means you don't get output (oh well maybe a MSB 1-value if rounding is applied to a LSB 255 value)
Changed the White & Amber channels to intensity also
Checked your project and I suspect that you stopped playing around since you didn't see some output...
I have added 2 buttons in your virtual desk to get this going in 'live' mode.
I guess this combination will actually work.
testROH.qxw
(4.11 KiB) Downloaded 92 times
(2.22 KiB) Downloaded 83 times
willmodelisme
Hi GGGss.
Many many thanks for your help.
I really appreciated.
Yes it works !!!
I still don't know why that fixture stopped to work on the 4.11 and above but I don't want to know to be honest.
I am currently reprogramming my show with the updated fixture you provided.
Thanks again for your support.
Enttec DMX USB Pro
Windows 10
