Update exitsting RPI intallation per "wget..."
Please follow the instructions of the provided PDF
Most likely you need to upgrade QLC+ and the Qt libraries
- Real Name: Tiago Vilhena de Oliveira
is it possible to update version QLC+ 4.12.0 instead of doing a complete installation?
You've been provided with an updated Debian package.
Just uninstall QLC+ 4.11.2 with
and then install QLC+ 4.12.0 with
sudo apt remove qlcplus
sudo dpkg -i qlcplus_4.12.0_armhf.deb
Great work and Thank you!
- Real Name: Ackermann Csaba
Hello!
I intsalled QLC+ 4.12.0 with sudo dpkg -i qlcplus_4.12.0_armhf.deb, but when I tried to start QLC+ I took an error message .
qlcplus:error while loading shared libraries: libQt5Script.so.5 : cannot open shared object file. No such file or directory.
On which image ?
That Debian package works with the official image, not every Debian in the world.
